Version: 3.5
Sorted streaming aggregate
Common aggregation methods in database systems include hash aggregate and sort aggregate.
From v2.5 onwards, StarRocks supports sorted streaming aggregate.
Working principles​
Aggregate nodes (AGG) are mainly responsible for handling GROUP BY and aggregate functions.
Sorted streaming aggregate can group data by comparing GROUP BY keys according to the sequence of the keys, without the need to create a hash table. This effectively reduces memory resources consumed by aggregation. For queries with a high aggregation cardinality, sorted streaming aggregate improves aggregation performance and reduces memory usage.
You can enable sorted streaming aggregate by setting the following variable:
Limits​
  • StarRocks shared-data clusters do not support sorted streaming aggregate.
  • The keys in GROUP BY must have a sequence. For example, if the sort key is k1, k2, k3, then:
    • GROUP BY k1 and GROUP BY k1, k2 are allowed.
    • GROUP BY k1, k3 does not follow the sort key sequence. Therefore, sorted streaming aggregate cannot take effect on such a clause.
  • The selected partition must be a single partition (because the same key may be distributed on different machines in different partitions).
  • The GROUP BY keys must have the same distribution as the bucket keys specified when you create a table. For example, if a table has three columns k1, k2, k3, the bucket key can be k1 or k1, k2.
    • If the bucket key is k1, the GROUP BY key can be k1, k1, k2, or k1, k2, k3.
    • If the bucket key is k1, k2, the GROUP BY key can be k1, k2 or k1, k2, k3.
    • If the query plans do not meet this requirement, the sorted streaming aggregate feature cannot take effect even if this feature is enabled.
  • Sorted streaming aggregate works only for first-stage aggregation (that is, there is only one Scan node under the AGG node).
  1. Create a table and insert data.
    ENGINE=OLAP
    DISTRIBUTED BY HASH(`id_int`)
    PROPERTIES
    ("replication_num" = "3");
    (1, 'v1'),
    (2, 'v2'),
    (3, 'v3'),
    (1, 'v4');
  2. Enable sorted streaming aggregate and use EXPLAIN to query the SQL profile.
    group by id_int;
Check whether sorted streaming aggregate is enabled​
View the results of EXPLAIN costs. If the sorted streaming field is true in the AGG node, this feature is enabled.
| | sorted streaming: true |
| | cardinality: 1 |
| | column statistics: |
| 0:OlapScanNode |
| preAggregation: on |
| cardinality: 1 |
