System limits
This topic describes the rules and limits that apply when you use StarRocks.
  • StarRocks uses the MySQL protocol for communication. You can connect to the StarRocks cluster via a MySQL client or JDBC. We recommend that you use a MySQL client whose version is 5.1 or later. Versions earlier than 5.1 do not support usernames that are longer than 16 characters.
  • Naming conventions for objects such as catalogs, databases, tables, views, asynchronous materialized views, partitions, columns, indexes, usernames, roles, repositories, resources, storage volumes, and pipes:
    • The name can only consist of digits (0-9), letters (a-z or A-Z), and underscores (_). Usernames can be all digits.
    • The name can start with a letter or an underscore (_).
    • The name cannot exceed 64 characters in length, among which:
      • Database name cannot exceed 256 characters.
      • Table name and column name cannot exceed 1024 characters.
      • Username cannot exceed 128 characters.
    • Column name (column alias), partition name, and index name are not case-sensitive. Other names are case-sensitive.
  • The FE configuration item enable_table_name_case_insensitive (supported from v4.0 onwards) allows you to control whether data directory names, database names, table names, view names, and asynchronous materialized view names are case-insensitive. Currently, table names are case-sensitive by default.
    • After enabling this feature, all related names will be stored in lowercase, and all SQL commands containing these names will automatically convert them to lowercase.
    • You can enable this feature only when creating a cluster. After the cluster is started, the value of this configuration cannot be modified by any means. Any attempt to modify it will result in an error. FE will fail to start when it detects that the value of this configuration item is inconsistent with that when the cluster was first started.
    • Currently, this feature does not support JDBC catalog and table names. Do not enable this feature if you want to perform case-insensitive processing on JDBC or ODBC data sources.
  • Naming conventions for labels: You can specify the label of a job when you load data. The label name can consist of digits (0-9), letters (a-z or A-Z), and underscores (_), and cannot exceed 128 characters in length. Label names can start with a letter or an underscore (_).
  • When you create a table, the key column cannot be of the FLOAT or DOUBLE type. You can use the DECIMAL type to represent decimals.
  • The maximum length of a VARCHAR value varies in different versions:
    • In versions earlier than StarRocks 2.1, the length ranges from 1 to 65533 bytes.
    • [Preview] In StarRocks 2.1 and later versions, the length ranges from 1 to 1048576 bytes. Maximum length of a VARCHAR value = Maximum row size (1048578 bytes) - Length prefix (2 bytes). The length prefix indicates the number of bytes in the value.
    • The default length is 1 byte.
  • StarRocks supports only UTF-8 encoding, not GBK.
  • StarRocks does not support modifying the table types of an existing table. For example, you cannot change a Duplicate Key table to a Primary Key table. You must create a new table.
  • By default, a query can be nested with a maximum of 10,000 subqueries, which is controlled by the FE parameter expr_children_limit.
