bool_or
Returns true if at least one row for expr is true. Otherwise, returns false. boolor_agg is an alias for this function.
bool_or(expr)
expr: The expression must evaluate to a boolean value, that is, true or false.
Returns a boolean value. An error is returned if expr does not exist.
Usage notes​
This function ignores NULL values.
  1. Create a table named employees.
    CREATE TABLE IF NOT EXISTS employees (
    region_num TINYINT,
    id BIGINT,
    is_manager BOOLEAN
    DISTRIBUTED BY HASH(region_num);
  2. Insert data into employees.
    INSERT INTO employees VALUES
    (3,432175, TRUE),
    (4,567832, FALSE),
    (3,777326, FALSE),
    (5,342611, TRUE),
    (2,403882, FALSE);
  3. Query data from employees.
    MySQL > select * from employees;
    | region_num | id | is_manager |
    | 3 | 432175 | 1 |
    | 4 | 567832 | 0 |
    | 3 | 777326 | 0 |
    | 5 | 342611 | 1 |
    | 2 | 403882 | 0 |
    5 rows in set (0.01 sec)
  4. Use this function to check for managers in each region.
    Example 1: Check if there is at least one manager in each region.
    MySQL > SELECT region_num, bool_or(is_manager) from employees
    group by region_num;
    | region_num | bool_or(is_manager) |
    | 3 | 1 |
    | 4 | 0 |
    | 5 | 1 |
    | 2 | 0 |
    4 rows in set (0.01 sec)
keyword​
BOOL_OR, bool_or, boolor_agg
