count_if
Returns the number of records that meet the specified condition or 0 if no records satisfy the condition.
This function does not support DISTINCT, for example count_if(DISTINCT x).
This function is internally transformed to COUNT + IF:
  • Before: COUNT_IF(x)
  • After: COUNT(IF(x, 1, NULL))
COUNT_IF(condition)
condition: the condition that should evaluate to a BOOLEAN value. You can specify multiple count_if conditions in one SELECT statement.
Returns a numeric value. If no records can be found, 0 is returned. This function ignores NULL values.
Suppose there is a table named test_count_if.
CREATE TABLE `test_count_if` (
`v1` varchar(65533) NULL COMMENT "",
`v2` varchar(65533) NULL COMMENT "",
`v3` datetime NULL COMMENT "",
`v4` int null
DUPLICATE KEY(v1, v2, v3)
PARTITION BY RANGE(`v3`)
(PARTITION p20220418 VALUES [("2022-04-18 00:00:00"), ("2022-04-19 00:00:00")),
PARTITION p20220419 VALUES [("2022-04-19 00:00:00"), ("2022-04-20 00:00:00")),
PARTITION p20220420 VALUES [("2022-04-20 00:00:00"), ("2022-04-21 00:00:00")),
PARTITION p20220421 VALUES [("2022-04-21 00:00:00"), ("2022-04-22 00:00:00")))
DISTRIBUTED BY HASH(`v1`) BUCKETS 4;
INSERT INTO test_count_if VALUES
('a','a', '2022-04-18 01:01:00', 1),
('a','b', '2022-04-18 02:01:00', NULL),
('a',NULL, '2022-04-18 02:05:00', 1),
('a','b', '2022-04-18 02:15:00', 3),
('a','b', '2022-04-18 03:15:00', 7),
('c',NULL, '2022-04-18 03:45:00', NULL),
('c',NULL, '2022-04-18 03:25:00', 2),
('c','a', '2022-04-18 03:27:00', 3);
SELECT * FROM test_count_if;
| v1 | v2 | v3 | v4 |
| a | NULL | 2022-04-18 02:05:00 | 1 |
| a | a | 2022-04-18 01:01:00 | 1 |
| a | b | 2022-04-18 02:01:00 | NULL |
| a | b | 2022-04-18 02:15:00 | 3 |
| a | b | 2022-04-18 03:15:00 | 7 |
| c | NULL | 2022-04-18 03:25:00 | 2 |
| c | NULL | 2022-04-18 03:45:00 | NULL |
| c | a | 2022-04-18 03:27:00 | 3 |
Example 1: Count the number of rows in table test_count_if where v2 is null.
select count_if(v2 is null) from test_count_if;
| count_if(v2 IS NULL) |
| 3 |
Example 2: Count the number of rows where v1 >= v2 or v4 = 1
select count_if(v1 >= v2 or v4 = 1)from test_count_if;
| count_if((v1 >= v2) OR (v4 = 1)) |
| 3 |
Example 3: Specify multiple conditions.
select count_if(v1 >= v2), count_if(v1 >= v2 or v4 = 1), count_if(v1 >= v2 and v4 = 1) from test_count_if;
| count_if(v1 >= v2) | count_if((v1 >= v2) OR (v4 = 1)) | count_if((v1 >= v2) AND (v4 = 1)) |
| 2 | 3 | 1 |
