ds_hll_combine
Combines multiple serialized HyperLogLog sketches into a single serialized sketch. This function is part of the DataSketches HLL family of functions for approximate distinct counting.
ds_hll_combine takes multiple VARBINARY serialized sketches created by ds_hll_accumulate and merges them into a single sketch that represents the union of all distinct values.
It is based on Apache DataSketches and provides high precision for approximate distinct counting. For more information, see HyperLogLog Sketches.
sketch ds_hll_combine(sketch)
  • sketch: A VARBINARY column containing serialized HyperLogLog sketches created by ds_hll_accumulate.
Return Type​
Returns a VARBINARY containing the combined serialized HyperLogLog sketch.
-- Create test table
CREATE TABLE t1 (
id BIGINT,
province VARCHAR(64),
age SMALLINT,
dt VARCHAR(10)
DUPLICATE KEY(id)
-- Insert test data
-- Create table to store sketches
CREATE TABLE t2 (
`id` bigint,
`dt` varchar(10),
`ds_id` binary,
`ds_province` binary,
`ds_age` binary,
`ds_dt` binary
-- Store sketches created by ds_hll_accumulate
INSERT INTO t2 SELECT id, dt,
ds_hll_accumulate(id),
ds_hll_accumulate(province, 10),
ds_hll_accumulate(age, 20, "HLL_6"),
FROM t1;
-- Combine sketches grouped by date
SELECT dt,
ds_hll_combine(ds_id),
ds_hll_combine(ds_province),
ds_hll_combine(ds_age),
ds_hll_combine(ds_dt)
FROM t2
GROUP BY dt
ORDER BY 1
LIMIT 3;
  • ds_hll_accumulate: Creates serialized HyperLogLog sketches from data
  • ds_hll_estimate: Estimates the distinct count from a serialized sketch
  • ds_hll_count_distinct: Direct approximate distinct counting function
Keywords​
ds_HLL_COMBINE, HLL, HYPERLOGLOG, APPROXIMATE, DISTINCT, COUNT, MERGE, UNION
