ds_hll_count_distinct
Returns the approximate value of aggregate function similar to the result of COUNT(DISTINCT col). APPROX_COUNT_DISTINCT(expr) is similar function.
ds_hll_count_distinct is faster than the COUNT and DISTINCT combination and uses a fixed-size memory, so less memory is required for columns of high cardinality.
It is slower than APPROX_COUNT_DISTINCT(expr) but with higher precision because it adopts of Apache Datasketches. For more information, see HyperLogLog Sketches.
ds_hll_count_distinct(expr, [log_k], [tgt_type])
  • log_k: Integer. Range [4, 21]. Default: 17.
  • tgt_type: Valid values are HLL_4, HLL_6 (default) and HLL_8.
mysql> CREATE TABLE t1 (
-> id BIGINT NOT NULL,
-> province VARCHAR(64),
-> age SMALLINT,
-> dt VARCHAR(10) NOT NULL
-> DUPLICATE KEY(id)
mysql> select ds_hll_count_distinct(id), ds_hll_count_distinct(province), ds_hll_count_distinct(age), ds_hll_count_distinct(dt) from t1 order by 1, 2;
| ds_hll_count_distinct(id) | ds_hll_count_distinct(province) | ds_hll_count_distinct(age) | ds_hll_count_distinct(dt) |
| 100090 | 100140 | 100 | 1 |
1 row in set (0.07 sec)
mysql> select ds_hll_count_distinct(id, 21), ds_hll_count_distinct(province, 21), ds_hll_count_distinct(age, 21), ds_hll_count_distinct(dt, 21) from t1 order by 1, 2;
| ds_hll_count_distinct(id, 21) | ds_hll_count_distinct(province, 21) | ds_hll_count_distinct(age, 21) | ds_hll_count_distinct(dt, 21) |
| 99995 | 100001 | 100 | 1 |
mysql> select ds_hll_count_distinct(id, 10, "HLL_8"), ds_hll_count_distinct(province, 10, "HLL_8"), ds_hll_count_distinct(age, 10, "HLL_8"), ds_hll_count_distinct(dt, 10, "HLL_8") from t1 order by 1, 2;
| ds_hll_count_distinct(id, 10, 'HLL_8') | ds_hll_count_distinct(province, 10, 'HLL_8') | ds_hll_count_distinct(age, 10, 'HLL_8') | ds_hll_count_distinct(dt, 10, 'HLL_8') |
| 99844 | 101905 | 96 | 1 |
1 row in set (0.09 sec)
Keywords​
DS_HLL_COUNT_DISTINCT,APPROX_COUNT_DISTINCT
