ds_hll_estimate
Estimates the approximate distinct count from a serialized HyperLogLog sketch. This function is part of the DataSketches HLL family of functions for approximate distinct counting.
ds_hll_estimate takes a VARBINARY serialized sketch created by ds_hll_accumulate or ds_hll_combine and returns the estimated number of distinct values.
It is based on Apache DataSketches and provides high precision for approximate distinct counting. For more information, see HyperLogLog Sketches.
bigint ds_hll_estimate(sketch)
  • sketch: A VARBINARY column containing serialized HyperLogLog sketches created by ds_hll_accumulate or ds_hll_combine.
Return Type​
Returns a BIGINT representing the estimated distinct count.
-- Create test table
CREATE TABLE t1 (
id BIGINT,
province VARCHAR(64),
age SMALLINT,
dt VARCHAR(10)
DUPLICATE KEY(id)
-- Insert test data
-- Create table to store sketches
CREATE TABLE t2 (
`id` bigint,
`dt` varchar(10),
`ds_id` binary,
`ds_province` binary,
`ds_age` binary,
`ds_dt` binary
-- Store sketches created by ds_hll_accumulate
INSERT INTO t2 SELECT id, dt,
ds_hll_accumulate(id),
ds_hll_accumulate(province, 10),
ds_hll_accumulate(age, 20, "HLL_6"),
FROM t1;
-- Estimate distinct counts grouped by date
SELECT dt,
ds_hll_estimate(ds_id),
ds_hll_estimate(ds_province),
ds_hll_estimate(ds_age),
ds_hll_estimate(ds_dt)
FROM t2
GROUP BY dt
ORDER BY 1
LIMIT 3;
  • ds_hll_accumulate: Creates serialized HyperLogLog sketches from data
  • ds_hll_combine: Combines multiple serialized sketches into a single sketch
  • ds_hll_count_distinct: Direct approximate distinct counting function
Keywords​
ds_HLL_ESTIMATE, HLL, HYPERLOGLOG, APPROXIMATE, DISTINCT, COUNT, ESTIMATE
