ds_theta_count_distinct
Returns the approximate value of aggregate function similar to the result of COUNT(DISTINCT col). ds_theta_count_distinct is faster than COUNT(DISTINCT col) and uses less memory for columns of high cardinality.
ds_theta_count_distinct is similar to APPROX_COUNT_DISTINCT(expr) and DS_HLL_COUNT_DISTINCT(expr) but with different precisions because it adopts Apache DataSketches. For more information, see Theta Sketches.
The relative error is 3.125% (95% confidence). For more information, see the relative error table.
BIGINT ds_theta_count_distinct(expr)
  • expr: The column in which to calculate the approximate count distinct values.
mysql> CREATE TABLE t1 (
-> id BIGINT NOT NULL,
-> province VARCHAR(64),
-> age SMALLINT,
-> dt VARCHAR(10) NOT NULL
-> DUPLICATE KEY(id)
mysql> select ds_theta_count_distinct(id), ds_theta_count_distinct(province), ds_theta_count_distinct(age), ds_theta_count_distinct(dt) from t1 order by 1, 2;
| ds_theta_count_distinct(id) | ds_theta_count_distinct(province) | ds_theta_count_distinct(age) | ds_theta_count_distinct(dt) |
| 100215 | 100846 | 100 | 1 |
1 row in set (0.62 sec)
Keywords​
DS_THETA_COUNT_DISTINCT,DS_HLL_COUNT_DISTINCT,APPROX_COUNT_DISTINCT
