array_contains_all
Checks whether arr1 contains all the elements of arr2, that is, whether arr2 is a subset of arr1. If yes, 1 is returned. If not, 0 is returned.
BOOLEAN array_contains_all(arr1, arr2)
arr: the two arrays to compare. This syntax checks whether arr2 is a subset of arr1.
The data types of elements in the two arrays must be the same. For the data types of array elements supported by StarRocks, see ARRAY.
Returns a value of the BOOLEAN type.
1 is returned if arr2 is a subset of arr1. Otherwise, 0 is returned.
If any of the two arrays is NULL, NULL is returned.
Usage notes​
  • If an array contains null elements, null is processed as a value.
  • An empty array is a subset of any array.
  • Elements in the two arrays can have different order.
  1. Create a table named t1 and insert data into this table.
    CREATE TABLE t1 (
    c0 INT,
    c1 ARRAY<INT>,
    c2 ARRAY<INT>
    DUPLICATE KEY(c0)
    DISTRIBUTED BY HASH(c0);
    INSERT INTO t1 VALUES
    (1,[1,2,3],[1,2]),
    (2,[1,2,3],[1,4]),
    (3,NULL,[1]),
    (4,[1,2,null],NULL),
    (5,[1,2,null],[null]),
    (6,[2,3],[]);
  2. Query data from this table.
    SELECT * FROM t1 ORDER BY c0;
    | c0 | c1 | c2 |
    | 1 | [1,2,3] | [1,2] |
    | 2 | [1,2,3] | [1,4] |
    | 3 | NULL | [1] |
    | 4 | [1,2,null] | NULL |
    | 5 | [1,2,null] | [null] |
    | 6 | [2,3] | [] |
  3. Check whether each row of c2 is a subset of the corresponding row of c1.
    SELECT c0, c1, c2, array_contains_all(c1, c2) FROM t1 ORDER BY c0;
    | c0 | c1 | c2 | array_contains_all(c1, c2) |
    | 1 | [1,2,3] | [1,2] | 1 |
    | 2 | [1,2,3] | [1,4] | 0 |
    | 3 | NULL | [1] | NULL |
    | 4 | [1,2,null] | NULL | NULL |
    | 5 | [1,2,null] | [null] | 1 |
    | 6 | [2,3] | [] | 1 |
In the output:
For row 1, c2 is a subset of c1 and 1 is returned.
For row 2, c2 is not a subset of c1 and 0 is returned.
For row 3, c1 is NULL and NULL is returned.
For row 4, c2 is NULL and NULL is returned.
For row 5, the two arrays contain null and null is processed as a normal value, 1 is returned.
For row 6, c2 is an empty array and considered a subset of c1. Therefore, 1 is returned.
