array_contains_seq
Checks whether all the elements of array2 appear in array1 in the same exact order. Therefore, the function will return 1, if and only if array1 = prefix + array2 + suffix.
For example:
select array_contains_seq([1,2,3,4], [1,2,3]);returns 1.select array_contains_seq([1,2,3,4], [4,3]);returns 0.
This function is supported from v3.3 onwards.
BOOLEAN array_contains_seq(arr1, arr2)
Parametersβ
arr: the two arrays to compare. This syntax checks whether arr2 is a subset of arr1 and in the same exact order.
The data types of elements in the two arrays must be the same. For the data types of array elements supported by StarRocks, see ARRAY.
Return valueβ
Returns a value of the BOOLEAN type.
1is returned ifarr2is a subset ofarr1and the elements inarr2observe the same order as those inarr1. Otherwise,0is returned.- An empty array is a subset of any array. Therefore,
1is returned ifarr2is empty butarr1is a valid array. - NULL is returned if any input array is NULL.
- Nulls in arrays are processed as normal values. For example,
SELECT array_contains_seq([1, 2, NULL, 3, 4], [2,3])will return 0. However,SELECT array_contains_seq([1, 2, NULL, 3, 4], [2,NULL,3])will return 1.
MySQL > select array_contains_seq([1,2,3,4], [1,2,3]);
| array_contains_seq([1, 2, 3, 4], [1, 2, 3]) |
MySQL > select array_contains_seq([1,2,3,4], [3,2]);
| array_contains_seq([1, 2, 3, 4], [3, 2]) |
| 0 |
MySQL > select array_contains_seq([1, 2, NULL, 3, 4], ['a']);
| array_contains_all([1, 2, NULL, 3, 4], ['a']) |
| 0 |
MySQL > select array_contains_seq([1,2,3,4,null], null);
| array_contains([1, 2, 3, 4, NULL], NULL) |
MySQL > select array_contains_seq([1,2,3,4], []);
| array_contains_seq([1, 2, 3, 4], []) |
