array_cum_sum
Returns the cumulative sums of elements in an array.
array_cum_sum(array(bigint))
array_cum_sum(array(double))
array: The elements in the array must be of the BIGINT (8-byte signed integer) or DOUBLE (8-byte floating-point number) type.
Return values​
Returns an array.
NULL is returned if the input array is NULL.
Example 1: Return the cumulative sums of an array.
select array_cum_sum([11, 11, 12]);
| array_cum_sum([11,11,12]) |
| [11,22,34] |
Example 2: Use this function with CAST.
select array_cum_sum([cast(11.33 as double),cast(11.11 as double),cast(12.324 as double)]);
| array_cum_sum([CAST(11.33 AS DOUBLE), CAST(11.11 AS DOUBLE), CAST(12.324 AS DOUBLE)]) |
| [11.33,22.439999999999998,34.763999999999996] |
Example 3: The input array contains a null.
select array_cum_sum([null,1,2]);
| array_cum_sum([null,1,2]) |
| [null,1,3] |
Example 4: The input array is null.
select array_cum_sum(null);
| array_cum_sum(NULL) |
