array_position
Obtains the position of an element in an array.
array_position(any_array, any_element)
  • any_array: the array to be searched.
  • any_element: an expression that matches the element in an array.
Returns the position of the specified element if the element can be found in the specified array and returns 0 if the element cannot be found in the array.
  • Example 1: Obtain the position of an element in an array.
mysql> select array_position(["apple","orange","pear"], "orange");
| array_position(['apple','orange','pear'], 'orange') |
| 2 |
  • Example 2: Obtain the position of NULL in an array.
mysql> select array_position([1, NULL], NULL);
| array_position([1,NULL], NULL) |
| 2 |
  • Example 3: Obtain the position of a sub-array in a multi-dimensional array. A position can be returned only when a sub-array that consists of the same elements in the same order as the specified sub-array can be found in the multi-dimensional array.
mysql> select array_position([[1,2,3], [4,5,6]], [4,5,6]);
| array_position([[1,2,3],[4,5,6]], [4,5,6]) |
| 2 |
mysql> select array_position([[1,2,3], [4,5,6]], [4,6,5]);
| array_position([[1,2,3],[4,5,6]], [4,6,5]) |
| 0 |
Keywords​
ARRAY_POSITION, ARRAY
