array_to_bitmap
Converts an array into BITMAP values. This function is supported from v2.3.
BITMAP array_to_bitmap(array)
array: Elements in an array can be of the BIGINT, INT, TINYINT, or SMALLINT type.
Returns a value of the BITMAP type.
Usage notes​
  • If the data type of elements in the input array is invalid, such as STRING or DECIMAL, an error is returned.
  • If an empty array is entered, an empty BITMAP value is returned.
  • If NULL is entered, NULL is returned.
Example 1: Convert an array into BITMAP values. This function must be nested in bitmap_to_array because BITMAP values cannot be displayed.
MySQL > select bitmap_to_array(array_to_bitmap([1,2,3]));
| bitmap_to_array(array_to_bitmap([1,2,3])) |
| [1,2,3] |
Example 2: Enter an empty array and an empty array is returned.
MySQL > select bitmap_to_array(array_to_bitmap([]));
| bitmap_to_array(array_to_bitmap([])) |
Example 3: Enter NULL and NULL is returned.
MySQL > select array_to_bitmap(NULL);
| array_to_bitmap(NULL) |
