element_at
Returns the element at the specified position (index) from a given array. If any parameter is NULL or if the position does not exist, the result is NULL.
This function is the alias of the subscript operator []. It is supported from v3.0 onwards.
If you want to retrieve a value from a key-value pair in a map, see element_at.
element_at(any_array, position)
  • any_array: an array expression from which to retrieve elements.
  • position: the position of the element in the array. It must be a positive integer. Value range: [1, array length]. If position does not exist, NULL is returned.
mysql> select element_at([2,3,11],3);
| [2, 3, 11][3] |
| 11 |
mysql> select element_at(["a","b","c"],1);
| ['a', 'b', 'c'][1] |
| a |
keyword​
ELEMENT_AT, ARRAY
