bitmap_agg
Aggregates values (excluding NULLs) in a column into a bitmap (multiple rows into one row).
BITMAP_AGG(col)
col: the column whose values you want to aggregate. It must evaluate to BOOLEAN, TINYINT, SMALLINT, INT, BIGINT, and LARGEINT.
Returns a value of the BITMAP type.
Usage notes​
If the value in a row is less than 0 or greater than 18446744073709551615, the value will be ignored and not added to the Bitmap (see Example 3).
Take the following data table as an example:
mysql> CREATE TABLE t1_test (
c1 int,
c2 boolean,
c3 tinyint,
c4 int,
c5 bigint,
c6 largeint
DUPLICATE KEY(c1)
DISTRIBUTED BY HASH(c1)
BUCKETS 1
INSERT INTO t1_test VALUES
(1, true, 11, 111, 1111, 11111),
(2, false, 22, 222, 2222, 22222),
(3, true, 33, 333, 3333, 33333),
(4, null, null, null, null, null),
(5, -1, -11, -111, -1111, -11111),
(6, null, null, null, null, "36893488147419103232");
select * from t1_test order by c1;
| c1 | c2 | c3 | c4 | c5 | c6 |
| 1 | 1 | 11 | 111 | 1111 | 11111 |
| 2 | 0 | 22 | 222 | 2222 | 22222 |
| 3 | 1 | 33 | 333 | 3333 | 33333 |
| 4 | NULL | NULL | NULL | NULL | NULL |
| 5 | 1 | -11 | -111 | -1111 | -11111 |
| 6 | NULL | NULL | NULL | NULL | 36893488147419103232 |
Example 1: Aggregate values in column c1 into one bitmap.
mysql> select bitmap_to_string(bitmap_agg(c1)) from t1_test;
| bitmap_to_string(bitmap_agg(c1)) |
| 1,2,3,4,5,6 |
Example 2: Aggregate values in column c2 into one bitmap (NULLs are ignored).
mysql> SELECT BITMAP_TO_STRING(BITMAP_AGG(c2)) FROM t1_test;
| bitmap_to_string(bitmap_agg(c2)) |
| 0,1 |
Example 3: Aggregate values in column c6 into one bitmap (the last two values that exceed the value range are ignored).
mysql> select bitmap_to_string(bitmap_agg(c6)) from t1_test;
| bitmap_to_string(bitmap_agg(c6)) |
| 11111,22222,33333 |
Keywords​
BITMAP_AGG, BITMAP
