bitmap_empty
Returns an empty bitmap. It is mainly used to fill in the default value during insert or stream load. For example:
-H "columns: dt,page,v1,v2=bitmap_empty()" \
BITMAP BITMAP_EMPTY()
MySQL > select bitmap_count(bitmap_empty());
| bitmap_count(bitmap_empty()) |
| 0 |
keyword​
BITMAP_EMPTY,BITMAP
