bitmap_min
Obtains the minimum value of a bitmap. If the bitmap is NULL, this function returns NULL. If the bitmap is empty, this function returns NULL by default.
bitmap_min(bitmap)
bitmap: the bitmap whose minimum value you want to obtain. Only the BITMAP data type is supported. You can specify a bitmap that you construct by using functions such as bitmap_from_string.
Returns a value of the LARGEINT data type.
MySQL > select bitmap_min(bitmap_from_string("0, 1, 2, 3"));
| bitmap_min(bitmap_from_string('0, 1, 2, 3')) |
| 0 |
MySQL > select bitmap_min(bitmap_from_string("-1, 0, 1, 2"));
| bitmap_min(bitmap_from_string('-1, 0, 1, 2')) |
MySQL > select bitmap_min(bitmap_empty());
| bitmap_min(bitmap_empty()) |
mysql> select bitmap_min(bitmap_from_string("16501189037412846863"));
| bitmap_min(bitmap_from_string('16501189037412846863')) |
| 16501189037412846863 |
1 row in set (0.03 sec)
