bitmap_subset_limit
Intercepts a specified number of elements from a BITMAP value with element value starting from start range. The output elements are a subset of src.
This function is mainly used for scenarios such as paginated queries. It is supported from v3.1.
This function is similar to sub_bitmap. The difference is that this function intercepts elements starting from an element value (start_range) whereas sub_bitmap intercepts elements starting from an offset.
BITMAP bitmap_subset_limit(BITMAP src, BIGINT start_range, BIGINT limit)
  • src: the BITMAP value from which to obtain elements.
  • start_range: the start range to intercept elements. It must be a BIGINT value. If the specified start range exceeds the maximum element of the BITMAP value and limit is positive, NULL is returned. See Example 4.
  • limit: the number of elements to obtain starting from start_range. Negative limits are counted from right to left. If the number of matching elements is less than the value of limit, all the matching elements are returned.
Returns a value of the BITMAP type. NULL is returned if any of the input parameters is invalid.
Usage notes​
  • The subset elements include start range.
  • Negative limits are counted from right to left. See example 3.
In the following examples, the input of bitmap_subset_limit() is the output of bitmap_from_string. For example, bitmap_from_string('1,1,3,1,5,3,5,7,7,9') returns 1, 3, 5, 7, 9. bitmap_subset_limit() takes this BITMAP value as the input.
Example 1: Obtain 4 elements from the BITMAP value with elements values starting from 1.
select bitmap_to_string(bitmap_subset_limit(bitmap_from_string('1,1,3,1,5,3,5,7,7,9'), 1, 4)) value;
| value |
| 1,3,5,7 |
Example 2: Obtain 100 elements from the BITMAP value with elements value starting from 1,. The limit exceeds the length of the BITMAP value and all the matching elements are returned.
select bitmap_to_string(bitmap_subset_limit(bitmap_from_string('1,1,3,1,5,3,5,7,7,9'), 1, 100)) value;
| value |
| 1,3,5,7,9 |
Example 3: Obtain -2 elements from the BITMAP value with elements value starting from 5 (counting from right to left).
select bitmap_to_string(bitmap_subset_limit(bitmap_from_string('1,1,3,1,5,3,5,7,7,9'), 5, -2)) value;
| value |
| 3,5 |
Example 4: The start range 10 exceeds the maximum element of the BITMAP value 1,3,5,7,9 and limit is positive. NULL is returned.
| value |
