bitmap_to_base64
Converts a bitmap to a Base64-encoded string. This function is supported from v2.5.
VARCHAR bitmap_to_base64(BITMAP bitmap)
bitmap: the bitmap to convert. This parameter is required. If the input value is invalid, an error is returned.
Returns a value of the VARCHAR type.
Example 1: Use this function with other bitmap functions.
select bitmap_to_base64(bitmap_from_string("0, 1, 2, 3"));
| bitmap_to_base64(bitmap_from_string('0, 1, 2, 3')) |
| AjowAAABAAAAAAADABAAAAAAAAEAAgADAA== |
select bitmap_to_base64(to_bitmap(1));
| bitmap_to_base64(to_bitmap(1)) |
| AQEAAAA= |
select bitmap_to_base64(bitmap_empty());
| bitmap_to_base64(bitmap_empty()) |
| AA== |
Example 2: Convert each value in a BITMAP column into Base64-encoded strings.
  1. Create an Aggregate table page_uv where the AGGREGATE KEY is (page_id, visit_date). This table contains a BITMAP column visit_users whose values are to be aggregated.
        CREATE TABLE `page_uv`
    (`page_id` INT NOT NULL,
    "storage_format" = "DEFAULT"
  2. Insert data into this table.
      insert into page_uv values
  3. Convert each value in the visit_users column into a Base64-encoded string.
      select page_id, bitmap_to_base64(visit_users) from page_uv;
    | page_id | bitmap_to_base64(visit_users) |
    | 1 | CgMAAAANAAAAAAAAABcAAAAAAAAAIQAAAAAAAAA= |
    | 1 | AQ0AAAA= |
    | 2 | ARcAAAA= |
