subdivide_bitmap
Splits a large bitmap into multiple sub-bitmaps.
This function is mainly used to export bitmaps. Bitmaps that are too large will exceed the maximum packet size allowed in the MySQL protocol.
BITMAP subdivide_bitmap(bitmap, length)
bitmap: The bitmap that needs to be split, required. length: The maximum length of each sub-bitmap, required. Bitmaps larger than this value will be split into multiple small bitmaps.
Returns multiple sub-bitmaps not larger than length.
Suppose there is a table t1, in which the c2 column is a BITMAP column.
-- Use bitmap_to_string() to convert values in `c2` into a string.
| c1 | bitmap_to_string(c2) |
| 1 | 1,2,3,4,5,6,7,8,9,10 |
-- Split `c2` into small bitmaps whose maximum length is 3.
mysql> select c1, bitmap_to_string(subdivide_bitmap) from t1, subdivide_bitmap(c2, 3);
| c1 | bitmap_to_string(subdivide_bitmap) |
| 1 | 1,2,3 |
| 1 | 4,5,6 |
| 1 | 7,8,9 |
| 1 | 10 |
