aes_decrypt
Uses the AES_128_ECB algorithm to decrypt a string and returns a binary string.
AES is short for advanced encryption standard and ECB is short for electronic code book. The key used to encrypt the string is a 128-bit string.
aes_decrypt(str,key_str);
str: the string to decrypt. It must be of the VARCHAR type.
key_str: the key used to encrypt str. It must be of the VARCHAR type.
Returns a value of the VARCHAR type. If the input is invalid, NULL is returned.
Decode a Base64 string and use this function to decrypt the decoded string into the original string.
mysql> select AES_DECRYPT(from_base64('uv/Lhzm74syo8JlfWarwKA==  '),'F3229A0B371ED2D9441B830D21A390C3');
| aes_decrypt(from_base64('uv/Lhzm74syo8JlfWarwKA== '), 'F3229A0B371ED2D9441B830D21A390C3') |
| starrocks |
