from_base64
Decodes a Base64-encoded string. This function is an inverse of to_base64.
from_base64(str);
str: the string to decode. It must be of the VARCHAR type.
Returns a value of the VARCHAR type. If the input is NULL or an invalid Base64 string, NULL is returned. If the input is empty, an error is returned.
This function accepts only one string. More than one input string causes an error.
mysql> select from_base64("starrocks");
| from_base64('starrocks') |
| ²֫®$ |
mysql> select from_base64('c3RhcnJvY2tz');
| from_base64('c3RhcnJvY2tz') |
| starrocks |
