md5sum_numeric
Calculates the 128-bit checksum of multiple strings. The checksum is represented by a decimal string of digits.
LARGEINT md5sum_numeric(VARCHAR expr,...);
expr: the string to calculate. It must be of the VARCHAR type.
Returns a checksum of the LARGEINT type. If the input is empty, an error is returned.
mysql> select md5sum_numeric("starrocks");
| md5sum_numeric('starrocks') |
| 328761383472799310362963866384446095221 |
mysql> select md5sum_numeric("starrocks","star");
| md5sum_numeric('starrocks', 'star') |
| 163436627872604162110984707546327199448 |
mysql> select md5sum_numeric(null);
| md5sum_numeric(NULL) |
| 281949768489412648962353822266799178366 |
