to_base64
Converts a string into a Base64-encoded string. This function is an inverse of from_base64.
to_base64(str);
str: the string to encode. It must be of the VARCHAR type.
Returns a value of the VARCHAR type. If the input is NULL, NULL is returned. If the input is empty, an error is returned.
This function accepts only one string. More than one input string causes an error.
mysql> select to_base64("starrocks");
| to_base64('starrocks') |
| c3RhcnJvY2tz |
mysql> select to_base64(123);
| to_base64(123) |
| MTIz |
