map_concat
Returns the union of the input maps. If a key is found in multiple maps, this function keeps only the last value among these maps, called LAST WIN. For example, SELECT map_concat(map{1:3},map{1:'4'}); returns {1:"4"}.
ANY_MAP map_concat(any_map0, any_map1...)
any_mapN: the map values you want to union. All maps must share a common type. If data types of the input maps are not the same, the return type is the common supertype of the input maps.
Returns a MAP of the common supertype of the input maps.
mysql> SELECT map_concat(map('a',1, 'b',2), map('c',3));
| map_concat(map{'a':1,'b':2}, map{'c':3}) |
| {"c":3,"a":1,"b":2} |
mysql> select map_concat(map{1:3},map{'3.323':3});
| map_concat(map{1:3}, map{'3.323':3}) |
| {"3.323":3,"1":3} |
mysql> select map_concat(map{1:3},map{1:'4', 3:'5',null:null}, null);
| map_concat(map{1:3}, map{1:'4',3:'5',NULL:NULL}, NULL) |
| {null:null,1:"4",3:"5"} |
