map_filter
Filters key-value pairs in a map by applying a Boolean array or a Lambda expression to each key-value pair. The pair that evaluates to true is returned.
MAP map_filter(any_map, array<boolean>)
MAP map_filter(lambda_func, any_map)
  • map_filter(any_map, array<boolean>)
    Evaluates key-value pairs in any_map one by one against array<boolean> and returns key-value pairs that evaluate to true.
  • map_filter(lambda_func, any_map)
    Applies lambda_func to the key-value pairs in any_map one by one and returns key-value pairs whose result is true.
  • any_map: the map value.
  • array<boolean>: the Boolean array used to evaluate the map value.
  • lambda_func: the Lambda expression used to evaluate the map value.
Returns a map whose data type is the same as any_map.
If any_map is NULL, NULL is returned. If array<boolean> is null, an empty map is returned.
If a key or value in the map value is NULL, NULL is processed as a normal value.
The Lambda expression must have two parameters. The first parameter represents the key. The second parameter represents the value.
Use array<boolean>​
The following example uses map_from_arrays() to generate a map value {1:"ab",3:"cdd",2:null,null:"abc"}. Then each key-value pair is evaluated against array<boolean> and the pair whose result is true is returned.
mysql> select map_filter(col_map, array<boolean>[0,0,0,1,1]) from (select map_from_arrays([1,3,null,2,null],['ab','cdd',null,null,'abc']) as col_map)A;
| map_filter(col_map, ARRAY<BOOLEAN>[0, 0, 0, 1, 1]) |
| {null:"abc"} |
1 row in set (0.02 sec)
mysql> select map_filter(null, array<boolean>[0,0,0,1,1]);
| map_filter(NULL, ARRAY<BOOLEAN>[0, 0, 0, 1, 1]) |
mysql> select map_filter(col_map, null) from (select map_from_arrays([1,3,null,2,null],['ab','cdd',null,null,'abc']) as col_map)A;
| map_filter(col_map, NULL) |
Use Lambda expression​
The following example uses map_from_arrays() to generate a map value {1:"ab",3:"cdd",2:null,null:"abc"}. Then each key-value pair is evaluated against the Lambda expression and the key-value pair whose value is not null is returned.
mysql> select map_filter((k,v) -> v is not null,col_map) from (select map_from_arrays([1,3,null,2,null],['ab','cdd',null,null,'abc']) as col_map)A;
| map_filter((k,v) -> v is not null, col_map) |
| {1:"ab",3:"cdd",null:'abc'} |
