map_size
Returns the number of elements in a MAP value. MAP is an unordered collection of key-value pairs, for example, {"a":1, "b":2}. One key-value pair constitutes one element, for example, {"a":1, "b":2} contains two elements.
This function has an alias cardinality(). It is supported from v2.5.
INT map_size(any_map)
any_map: the MAP value from which you want to retrieve the number of elements.
Returns a value of the INT type.
If the input is NULL, NULL is returned.
If a key or value in the MAP value is NULL, NULL is processed as a normal value.
Query MAP data from a StarRocks native table​
From v3.1 onwards, StarRocks supports defining MAP columns when you create a table. This example uses table test_map, which contains the following data:
CREATE TABLE test_map(
col_int INT,
col_map MAP<VARCHAR(50),INT>
DUPLICATE KEY(col_int);
INSERT INTO test_map VALUES
(1,map{"a":1,"b":2}),
(2,map{"c":3}),
(3,map{"d":4,"e":5});
| col_int | col_map |
| 1 | {"a":1,"b":2} |
| 2 | {"c":3} |
| 3 | {"d":4,"e":5} |
3 rows in set (0.05 sec)
Obtain the number of elements in each row of the col_map column.
select map_size(col_map) from test_map order by col_int;
| map_size(col_map) |
| 2 |
| 2 |
Query MAP data from data lake​
This example uses Hive table hive_map, which contains the following data:
| col_int | col_map |
| 1 | {"a":1,"b":2} |
| 2 | {"c":3} |
| 3 | {"d":4,"e":5} |
After a Hive catalog is created in your cluster, you can use this catalog and the map_size() function to obtain the number of elements in each row of the col_map column.
select map_size(col_map) from hive_map order by col_int;
| map_size(col_map) |
| 2 |
| 2 |
