percentile_union
Aggregates PERCENTILE data.
percentile_union(expr);
expr: The supported data type is PERCENTILE.
Returns a PERCENTILE value.
Example 1: Use percentile data in materialized views.
Create a table.
CREATE TABLE sales_records(
record_id int,
seller_id int,
store_id int,
sale_date date,
sale_amt bigint
) distributed BY hash(record_id)
Create a materialized view based on the sale_amt column of the table.
create materialized view mv as
select store_id, percentile_union(percentile_hash(sale_amt))
from sales_records
group by store_id;
Example 2: Load PERCENTILE data.
Create an Aggregate table that contains a PERCENTILE column sale_amt_per.
record_id int,
seller_id int,
store_id int,
sale_amt_per percentile percentile_union
AGGREGATE KEY(`record_id`, `seller_id`, `store_id`)
DISTRIBUTED BY HASH(`record_id`)
"storage_format" = "DEFAULT"
Query data from sale_amt_per.
select percentile_approx_raw(percentile_union(sale_amt_per), 0.99) from sales_records;
Load data that contains PERCENTILE data into the sales_records table.
curl --location-trusted -u root
-H "columns: record_id, seller_id, store_id,tmp, sale_amt_per =percentile_hash(tmp)"
-H "column_separator:,"
-T a http://<ip:port>/api/test/sales_records/_stream_load
