append_trailing_char_if_absent
If the str string is not empty and does not contain trailing_char character in the end, it appends trailing_char character to the end. trailing_char can only contain one character. If it contains multiple characters, this function will return NULL.
VARCHAR append_trailing_char_if_absent(VARCHAR str, VARCHAR trailing_char)
MySQL [test]> select append_trailing_char_if_absent('a','c');
|append_trailing_char_if_absent('a', 'c') |
| ac |
1 row in set (0.02 sec)
MySQL [test]> select append_trailing_char_if_absent('ac','c');
|append_trailing_char_if_absent('ac', 'c') |
| ac |
keyword​
APPEND_TRAILING_CHAR_IF_ABSENT
