concat_ws
This function uses the first argument sep as the separator which combines the second with the rest to form a string. If the separator is NULL, the result is NULL. concat_ws does not skip empty strings, but it will skip NULL values.
VARCHAR concat_ws(VARCHAR sep, VARCHAR str,...)
MySQL > select concat_ws("Rock", "Star", "s");
| concat_ws('Rock', 'Star', 's') |
| StarRocks |
MySQL > select concat_ws(NULL, "Star", "s");
| concat_ws(NULL, 'Star', 's') |
MySQL > StarRocks > select concat_ws("Rock", "Star", NULL, "s");
| concat_ws('Rock', 'Star', NULL, 's') |
| StarRocks |
1 row in set (0.04 sec)
keyword​
CONCAT_WS,CONCAT,WS
