hex_decode_binary
Decodes a hex encoded string to a binary.
hex_decode_binary(str);
str: the string to convert. The supported data type is VARCHAR.
An empty binary is returned if any of the following situations occur:
  • The length of the string is 0 or the number of characters in the string is an odd number.
  • The string contains characters other than [0-9], [a-z], and [A-Z].
Returns a value of the VARBINARY type.
mysql> select hex(hex_decode_binary(hex("Hello StarRocks")));
| hex(hex_decode_binary(hex('Hello StarRocks'))) |
| 48656C6C6F2053746172526F636B73 |
mysql> select hex_decode_binary(NULL);
| hex_decode_binary(NULL) |
Keywords​
HEX_DECODE_BINARY
