parse_url
Parses a URL and extracts a component from this URL.
parse_url(expr1,expr2);
Parametersβ
expr1: the URL. The supported data type is VARCHAR.
expr2: the component to extract from this URL. The supported data type is VARCHAR. Valid values:
- PROTOCOL
- HOST
- PATH
- REF
- AUTHORITY
- FILE
- USERINFO
- QUERY. Parameters in QUERY cannot be returned. If you want to return specific parameters, use parse_url with trim to achieve this implementation. For details, see Examples.
expr2 is case-sensitive.
Return valueβ
Returns a value of the VARCHAR type. If the URL is invalid, an error is returned. If the requested information cannot be find, NULL is returned.
select parse_url('http://facebook.com/path/p1.php?query=1', 'HOST');
| parse_url('http://facebook.com/path/p1.php?query=1', 'HOST') |
| facebook.com |
select parse_url('http://facebook.com/path/p1.php?query=1', 'AUTHORITY');
| parse_url('http://facebook.com/path/p1.php?query=1', 'AUTHORITY') |
| facebook.com |
select parse_url('http://facebook.com/path/p1.php?query=1', 'QUERY');
| parse_url('http://facebook.com/path/p1.php?query=1', 'QUERY') |
| query=1 |
select trim(parse_url('http://facebook.com/path/p1.php?query=1', 'QUERY'),'query=');
| trim(parse_url('http://facebook.com/path/p1.php?query=1', 'QUERY'), 'query=') |
