str_to_map
Splits a given string into key-value pairs using two delimiters and returns a map of the split pairs.
MAP<VARCHAR, VARCHAR> str_to_map(VARCHAR content[, VARCHAR delimiter[, VARCHAR map_delimiter]])
  • content: required, the string expression to split.
  • delimiter: optional, the delimiter used to split content into key-value pairs, defaults to ,.
  • map_delimiter: optional, the delimiter used to separate each key-value pair, defaults to :.
Returns a MAP of STRING elements. Any null input results in NULL.
mysql> SELECT str_to_map('a:1|b:2|c:3', '|', ':') as map;
| map |
| {"a":"1","b":"2","c":"3"} |
mysql> SELECT str_to_map('a:1;b:2;c:3', ';', ':') as map;
| map |
mysql> SELECT str_to_map('a:1,b:2,c:3', ',', ':') as map;
| map |
mysql> SELECT str_to_map('a') as map;
| map |
| {"a":null} |
mysql> SELECT str_to_map('a:1,b:2,c:3',null, ':') as map;
| map |
mysql> SELECT str_to_map('a:1,b:2,c:null') as map;
| map |
| {"a":"1","b":"2","c":"null"} |
keywords​
STR_TO_MAP
