url_encode
Translates a string into the application/x-www-form-urlencoded format.
This functions is supported from v3.2.
VARCHAR url_encode(VARCHAR str)
  • str: the string to encode. If str is not a string, this function will try implicit cast first.
Returns an encoded string compliant with the application/x-www-form-urlencoded format.
mysql> select url_encode('https://docs.starrocks.io/docs/introduction/StarRocks_intro/');
| url_encode('https://docs.starrocks.io/docs/introduction/StarRocks_intro/') |
| https%3A%2F%2Fdocs.starrocks.io%2Fdocs%2Fintroduction%2FStarRocks_intro%2F |
