url_extract_parameter
Extracts the value of the requested name parameter from the query string of a URL. Parameter extraction is handled in the manner as specified in RFC 1866#section-8.2.1. If the specified parameter name does not exist, NULL is returned.
This function is supported from v3.2.
VARCHAR url_extract_parameter(VARCHAR str, VARCHAR name)
  • str: the URL string to extract parameters.
  • name: the name of the parameter in the query string.
Returns a VARCHAR value.
mysql> select url_extract_parameter("https://starrocks.io/doc?k1=10&k2=3&k1=100", "k1");
| url_extract_parameter('https://starrocks.io/doc?k1=10&k2=3&k1=100', 'k1') |
| 10 |
mysql> select url_extract_parameter('https://starrocks.com/doc?k0=10&k1=%21%23%24%26%27%28%29%2A%2B%2C%2F%3A%3B%3D%3F%40%5B%5D%20%22%25%2D%2E%3C%3E%5C%5E%5F%60%7B%7C%7D%7E&k2','k1');
| url_extract_parameter('https://starrocks.com/doc?k0=10&k1=%21%23%24%26%27%28%29%2A%2B%2C%2F%3A%3B%3D%3F%40%5B%5D%20%22%25%2D%2E%3C%3E%5C%5E%5F%60%7B%7C%7D%7E&k2', 'k1') |
| !#$&'()*+,/:;=?@[] "%-.<>\^_`{|}~ |
