named_struct
Creates a struct with the specified field names and values.
STRUCT named_struct({STRING name1, ANY val1} [, ...] )
Parametersβ
nameN: A STRING field. -
valN: An expression of any type that specifies the value for field N. Values are nullable.
The expressions of names and values must be in pairs. Otherwise, the struct cannot be created. You must pass at least one pair of field name and value, separated by a comma (,).
Return valueβ
Returns a STRUCT value.
SELECT named_struct('a', 1, 'b', 2, 'c', 3);
| named_struct('a', 1, 'b', 2, 'c', 3) |
| {"a":1,"b":2,"c":3} |
SELECT named_struct('a', null, 'b', 2, 'c', 3);
| named_struct('a', null, 'b', 2, 'c', 3) |
| {"a":null,"b":2,"c":3} |
