SHOW PROPERTY
SHOW PROPERTY displays properties of a user. Currently, only the maximum number of connections can be viewed using this command.
tip
The current user can view its own property. Only users with the user_admin role can view the property of other users.
SHOW PROPERTY [FOR 'user_name'] [LIKE '<property_name>']
ParameterRequiredDescription
user_nameNoThe user name. If not specified, the property of the current user is viewed.
property_nameNoThe user property name.
Example 1: View the property the current user.
SHOW PROPERTY;
| Key | Value |
| max_user_connections | 10000 |
Example 2: View the property of the user jack.
SHOW PROPERTY FOR 'jack';
Or
SHOW PROPERTY FOR 'jack' LIKE 'max_user_connections';
| Key | Value |
| max_user_connections | 100 |
See also​
ALTER USER: Sets properties for a user.
