SHOW ROLES
SHOW ROLES displays all roles in the system. You can use SHOW GRANTS FOR ROLE <role_name>; to view the privileges of a specific role. For more information, see SHOW GRANTS.
This command is supported from v3.0.
tip
Only users with the user_admin role has the privilege to perform this operation.
SHOW ROLES
Return fields:
FieldDescription
NameThe name of the role.
Display all roles in the system.
mysql> SHOW ROLES;
| Name |
| root |
| db_admin |
| cluster_admin |
| user_admin |
| public |
| testrole |
References​
