DROP ANALYZE
DROP ANALYZE deletes a custom collection task.
By default, StarRocks automatically collects full statistics of a table. It checks for any data updates every 5 minutes. If data change is detected, data collection will be automatically triggered. If you do not want to use automatic full collection, you can set the FE configuration item enable_collect_full_statistic to false and customize a collection task.
This statement is supported from v2.4.
DROP ANALYZE <ID>
DROP ANALYZE 266030;
References​
CREATE ANALYZE: customize an automatic collection task.
SHOW ANALYZE JOB: view the status of an automatic collection task.
KILL ANALYZE: cancel a custom collection task that is running.
For more information about collecting statistics for CBO, see Gather statistics for CBO.
