SHOW TRANSACTION
SHOW TRANSACTION is used to view the transaction details of the specified transaction id.
Syntax:
SHOW TRANSACTION
[FROM <db_name>]
WHERE id = transaction_id
Examples of returned results:
TransactionId: 4005
Label: insert_8d807d5d-bcdd-46eb-be6d-3fa87aa4952d
Coordinator: FE: 10.74.167.16
TransactionStatus: VISIBLE
LoadJobSourceType: INSERT_STREAMING
PrepareTime: 2020-01-09 14:59:07
PreparedTime: 2020-01-09 14:59:08
CommitTime: 2020-01-09 14:59:09
FinishTime: 2020-01-09 14:59:09
Reason:
ErrorReplicasCount: 0
ListenerId: -1
TimeoutMs: 300000
PreparedTimeoutMs: 86400000
  • TransactionId: transaction id
  • Label: import the label corresponding to the task
  • Coordinator: the node responsible for transaction coordination
  • TransactionStatus: transaction status
  • PREPARE: preparation stage
  • COMMITTED: the transaction succeeded, but the data is not visible
  • VISIBLE: the transaction is successful and the data is visible
  • ABORTED: transaction failed
  • LoadJobSourceType: type of import task.
  • PrepareTime: transaction start time
  • PreparedTime: the time when the transaction is successfully prepared (supported from v3.5.4)
  • CommitTime: the time when the transaction is successfully committed
  • FinishTime: the time when the data is visible
  • Reason: error message
  • ErrorReplicasCount: number of replicas with errors
  • ListenerId: id of the related import job
  • TimeoutMs: timeout for the transaction from PREPARE to PREPARED state, in milliseconds
  • PreparedTimeoutMs: timeout for the transaction from PREPARED to COMMITTED state, in milliseconds (supported from v3.5.4)
  1. To view a transaction with id 4005:
    SHOW TRANSACTION WHERE ID=4005;
  2. In the specified dB, view the transaction with id 4005:
    SHOW TRANSACTION FROM db WHERE ID=4005;
