DROP MATERIALIZED VIEW
DROP MATERIALIZED VIEW drops a materialized view.
You cannot drop a synchronous materialized view that is being created in process with this command. To drop a synchronous materialized view that is being created in process, see Synchronous materialized View - Drop an unfinished materialized view for further instructions.
tip
This operation requires the DROP privilege on the target materialized view.
DROP MATERIALIZED VIEW [IF EXISTS] [database.]mv_name
Parameters in brackets [] is optional.
ParameterRequiredDescription
IF EXISTSnoIf this parameter is specified, StarRocks will not throw an exception when deleting a materialized view that does not exist. If this parameter is not specified, the system will throw an exception when deleting a materialized view that does not exist.
mv_nameyesThe name of the materialized view to delete.
Example 1: Drop an existing materialized view
  1. View all existing materialized views in the database.
MySQL > SHOW MATERIALIZED VIEWS\G
database_name: default_cluster:sr_hub
text: SELECT `sr_hub`.`orders`.`dt` AS `dt`, `sr_hub`.`orders`.`order_id` AS `order_id`, `sr_hub`.`orders`.`user_id` AS `user_id`, sum(`sr_hub`.`orders`.`cnt`) AS `total_cnt`, sum(`sr_hub`.`orders`.`revenue`) AS `total_revenue`, count(`sr_hub`.`orders`.`state`) AS `state_count` FROM `sr_hub`.`orders` GROUP BY `sr_hub`.`orders`.`dt`, `sr_hub`.`orders`.`order_id`, `sr_hub`.`orders`.`user_id`
rows: 0
1 rows in set (0.00 sec)
  1. Drop the materialized view order_mv1.
DROP MATERIALIZED VIEW order_mv1;
  1. Check if the dropped materialized view exists.
MySQL > SHOW MATERIALIZED VIEWS;
Empty set (0.01 sec)
Example 2: Drop a non-existing materialized view
  • If the parameter IF EXISTS is specified, StarRocks will not throw an exception when deleting a materialized view that does not exist.
MySQL > DROP MATERIALIZED VIEW IF EXISTS k1_k2;
Query OK, 0 rows affected (0.00 sec)
  • If the parameter IF EXISTS is not specified, the system will throw an exception when deleting a materialized view that does not exist.
MySQL > DROP MATERIALIZED VIEW k1_k2;
ERROR 1064 (HY000): Materialized view k1_k2 is not find
