CANCEL ALTER TABLE
CANCEL ALTER TABLE cancels the execution of the ongoing ALTER TABLE operation, including:
- Modify columns.
- Optimize table schema (from v3.2), including modifying the bucketing method and the number of buckets.
- Create and delete the rollup index.
- This statement is a synchronous operation.
- This statement requires you to have the
ALTER_PRIVprivilege on the table. - This statement only supports canceling asynchronous operations using ALTER TABLE (as mentioned above) and does not support canceling synchronous operations using ALTER TABLE, such as rename.
CANCEL ALTER TABLE { COLUMN | OPTIMIZE | ROLLUP } FROM [db_name.]table_name [ (rollup_job_id [, rollup_job_id]) ]
Parametersβ
{COLUMN ο½ OPTIMIZE | ROLLUP}- If
COLUMNis specified, this statement cancels operations of modifying columns. - If
OPTIMIZEis specified, this statement cancels operations of optimizing table schema. - If
ROLLUPis specified, this statement cancels operations of adding or deleting the rollup index. You can further specifyrollup_job_idto cancel specific rollup jobs.
- If
db_name: optional. The name of the database to which the table belongs. If this parameter is not specified, your current database is used by default. -
table_name: required. The table name. -
rollup_job_id: optional. The ID of the rollup job. You can get the rollup job ID using SHOW ALTER MATERIALIZED VIEW.
Cancel the operation of modifying columns for
example_tablein the databaseexample_db.CANCEL ALTER TABLE COLUMN FROM example_db.example_table; -
Cancel the operation of optimizing table schema for
example_tablein the databaseexample_db.CANCEL ALTER TABLE OPTIMIZE FROM example_db.example_table; -
Cancel the operation of adding or deleting the rollup index for
example_tablein the current database.CANCEL ALTER TABLE ROLLUP FROM example_table; -
Cancel specific rollup alterations for
example_tablein the current database using their job IDs.CANCEL ALTER TABLE ROLLUP FROM example_table (12345, 12346);
