SHOW DELETE
SHOW DELETE queries historical DELETE operations that were successfully performed on Duplicate Key, Unique Key, and Aggregate tables in a specified database. For more information about data deletion, see DELETE.
Note that this command cannot be used to query DELETE operations that were performed on Primary Key tables.
SHOW DELETE [FROM <db_name>]
db_name: the database name, optional. If this parameter is not specified, the current database is used by default.
Return fields:
  • TableName: the table from which data is deleted.
  • PartitionName: the partition from which data is deleted. If the table is a non-partitioned table, * is displayed.
  • CreateTime: the time when the DELETE task was created.
  • DeleteCondition: the specified DELETE condition.
  • State: the status of the DELETE task.
Show all historical DELETE operations of database.
SHOW DELETE FROM database;
| TableName | PartitionName | CreateTime | DeleteCondition | State |
| mail_merge | * | 2023-03-14 10:39:03 | name EQ "Peter" | FINISHED |
