ds_hll_count_distinct
返回聚合函数的近似值,结果类似于 COUNT(DISTINCT col)。相似函数为 APPROX_COUNT_DISTINCT(expr)。
相较于 COUNT DISTINCT 速度更快,并且使用固定大小的内存,因此基于高基数列使用时内存占用更少。
相较于 APPROX_COUNT_DISTINCT(expr) 速度更慢,但由于 Apache Datasketches 的优势,导致其精度更高。更多信息,参考 HyperLogLog Sketches
ds_hll_count_distinct(expr, [log_k], [tgt_type])
  • log_k:必须为整数。范围:[4, 21]。默认值:17。
  • tgt_type:有效值为 HLL_4HLL_6(默认)以及 HLL_8
mysql> CREATE TABLE t1 (
-> id BIGINT NOT NULL,
-> province VARCHAR(64),
-> age SMALLINT,
-> dt VARCHAR(10) NOT NULL
-> DUPLICATE KEY(id)
mysql> select ds_hll_count_distinct(id), ds_hll_count_distinct(province), ds_hll_count_distinct(age), ds_hll_count_distinct(dt) from t1 order by 1, 2;
| ds_hll_count_distinct(id) | ds_hll_count_distinct(province) | ds_hll_count_distinct(age) | ds_hll_count_distinct(dt) |
| 100090 | 100140 | 100 | 1 |
1 row in set (0.07 sec)
mysql> select ds_hll_count_distinct(id, 21), ds_hll_count_distinct(province, 21), ds_hll_count_distinct(age, 21), ds_hll_count_distinct(dt, 21) from t1 order by 1, 2;
| ds_hll_count_distinct(id, 21) | ds_hll_count_distinct(province, 21) | ds_hll_count_distinct(age, 21) | ds_hll_count_distinct(dt, 21) |
| 99995 | 100001 | 100 | 1 |
mysql> select ds_hll_count_distinct(id, 10, "HLL_8"), ds_hll_count_distinct(province, 10, "HLL_8"), ds_hll_count_distinct(age, 10, "HLL_8"), ds_hll_count_distinct(dt, 10, "HLL_8") from t1 order by 1, 2;
| ds_hll_count_distinct(id, 10, 'HLL_8') | ds_hll_count_distinct(province, 10, 'HLL_8') | ds_hll_count_distinct(age, 10, 'HLL_8') | ds_hll_count_distinct(dt, 10, 'HLL_8') |
| 99844 | 101905 | 96 | 1 |
1 row in set (0.09 sec)
Keywords
DS_HLL_COUNT_DISTINCT,APPROX_COUNT_DISTINCT
